Author Topic: Code Generation on self referential aggregation  (Read 3249 times)
nifsmith
« on: February 15, 2006, 01:49:33 pm »
Generating code from EA for a class aggregating itself (having set ArrayList as the default collection for C#) within EA does not generate code to include an ArrayList to hold the self reference.
The code generator will however create an ArrayList to hold a collection if the aggregation is between two different classes.
Also I don't seen to be able to alter (bend line at cursor) or stretch a self referential link to fit.
People should not be afraid of their Governments. Governments should be afraid of their people.
V
sargasso
Re: Code Generation on self referential aggregatio
« Reply #1 on: February 15, 2006, 01:53:55 pm »
FDE!  (Frequently demanded enhancement).
 Sounds like a problem I'm having myself, could you expand a bit more.
bruce
« Reply #2 on: February 15, 2006, 02:05:03 pm »
Now now, young bruce, you know it should be an:
  FRE!  (Frequently requested enhancement)
You've seen how far demanding has got us...  :-X
« Reply #3 on: February 15, 2006, 02:50:28 pm »
I'll expand on the code generation issue.
Currently a self-aggregation drawn in the default way will not generate an attribute at all.  There is a fix for this coming, but I don't expect it to come until build 788.
There are a couple of workarounds to the issue that I've found.
1. Use an association without setting the aggregation on either end.
2. Here's the devious one,  ;) Swap the information in the source role and target role.  I'm guessing that nifsmith's link has the following properties.
Source Role:
- Multiplicity 0..*
- Aggregation none
Target Role:
- Aggregation shared
If you change that to the following it should work as you expect. :)
Source Role:
Target Role:
- Multiplicity 0..*
- Aggregation none
