Author Topic: Actionscript 2.0 Interface bug with fix  (Read 2844 times)
sunetos
« on: February 08, 2006, 12:03:59 pm »
By the way, the Actionscript Code Generation Templates do not correctly handle Interfaces: they include empty {} for the body of methods in Interfaces, which is incorrect, and causes at least the mtasc compiler to fail.  To quick-fix, simply paste the following into the top of the Template "Operation Body" for ActionScript:
%if elemType=="Interface"%
%endTemplate%
And to get that semicolon on the same line as the method declaration, update the "Operation" template for ActionScript to be:
%OperationNotes%
%OperationDeclaration%%OperationBody%
Interface methods should only be declarations: they should not contain defined method bodies.
« Last Edit: February 08, 2006, 12:04:46 pm by sunetos »
Re: Actionscript 2.0 Interface bug with fix
« Reply #1 on: February 09, 2006, 02:05:18 pm »
Thanks for reporting the problem.
I've just modified the default templates with the following.
Operation Template
%OperationNotes%
%PI=""%
%endIf%
%OperationBody%
Operation Body Template
%endTemplate%
$wrap = %genOptWrapComment=="-1" ? "-1" : "40"%
$behaviour = %WRAP_LINES(opBehaviour, $wrap, "\t//", "")%
%if $behaviour != ""%
$behaviour\n\n
%endIf%
%if opCode != ""%
%WRAP_LINES(opCode, "-1", "\t", "")%
%elseIf opStereotype == "property get" and opTag:"attribute_name" != ""%
\treturn %opTag:"attribute_name"%;
%elseIf opStereotype == "property set" and opTag:"attribute_name" != ""%
\t%opTag:"attribute_name"% = newVal;
%endIf%
sunetos
« Reply #2 on: February 24, 2006, 07:02:44 am »
Thanks!  I was glad to see the Actionscript updates in build 787.
