Author Topic: Namespace containment in MDG SysML Plug-In  (Read 10347 times)
acme82
« on: November 14, 2007, 05:04:37 am »
according to the SysML specification [1] (e.g. p. 39) there is an element marking a so-called "namespace containment" which describes that a certain requirement contains one or more other requirements. The symbol of this association is a circle containing a cross. Unfortunately, I am not able to find this symbol in the MDG SysML Plug-In. Is there an equivalent or which kind of association is to be used to model namespace containment?
Thanks and kind regards,
Markus Müller
[1] http://www.sysml.org/docs/specs/OMGSysML-PAS-07-02-03.pdf
Re: Namespace containment in MDG SysML Plug-In
« Reply #1 on: November 14, 2007, 05:27:36 am »
Markus,
That's the Nesting connector in EA.
It's implementation may not be correct for your needs, but I think conceptually it fits...  Check out the Help.
« Reply #2 on: November 14, 2007, 05:58:12 am »
Markus,
I wonder if it can be set by setting a tagged value on the association, or perhaps one of the association ends.
Some of the BPMN stuff draws itself differently depending on tagged values.
acme82
« Reply #3 on: November 15, 2007, 01:33:40 am »
thanks for your help. The nesting connector works fine  :D
Markus
