Author Topic: RTF Document Tables  (Read 3003 times)
AlTumes
  • Reality leaves a lot to the imagination
RTF Document Tables
« on: March 03, 2006, 09:13:16 am »
I'm trying to set up some standard RTF Document templates that reflect our project standards. The problem I have is setting up tables.
Basically, when I set up the table, I go through the following process:
  • I place the titles in the first row,
  • I add the required element fields in the second row, and
  • I remove any line between the end of the table and the end of the section to which I am adding the table - this is to ensure the table does not create extra lines when generated.
When I generate the report, I get a document that has multiple tables each with a heading row and one row of details.
Has anyone else had this problem ? If so, I would be intrigued to know how you can get this to work properly.
Cheers,
pbergman
Re: RTF Document Tables
« Reply #1 on: March 07, 2006, 02:02:25 pm »
I have a very similar problem.
I also make sure that I don't have any line breaks after the table.
The end result is that the column headings, which I placed on the first row, are repeated for each item as seen below
Title1Title2
Item1.NameItem1.Notes
Title1Title2
Item2.NameItem2.Notes
Any suggestions are welcome.
/Per
