Author Topic: Protected Text in RTF template editor  (Read 4512 times)
malmoth
  • On ne réveille pas un malmoth qui dort
« on: March 05, 2006, 11:43:28 pm »
The documentation says 'The protection lock can be turned off by using an option from the Other menu.' But I cannot find this option in the Other menu of EA 6.1.787
Malmoth
alesliehughes
Re: Protected Text in RTF template editor
« Reply #1 on: March 06, 2006, 02:35:57 pm »
This has been fixed in Build 788
malmoth
« Reply #2 on: March 07, 2006, 11:25:37 am »
I'm sorry, but I still can see the protection lock option in the other menu with the 788 build.
« Last Edit: March 07, 2006, 11:26:05 am by rejaudry »
Malmoth
alesliehughes
« Reply #3 on: March 07, 2006, 02:05:56 pm »
Sorry I wasnt clear.  The bug was within the reports themselves and there isnt an option to turn protected fields off
malmoth
« Reply #4 on: March 08, 2006, 04:34:33 am »
So what exactly is Protected Text, if not protected field ?
Protected Text
The text formatted with this attribute are protected from the editing changes. The protected text appears with a light shade in the window. This function is available only when the protection lock is turned off. The protection lock can be turned off by using an option from the Other menu.
Malmoth
alesliehughes
« Reply #5 on: March 09, 2006, 02:39:15 pm »
Protected Text is exactly that, protected.  The issue was that the fields like {Element.Name} where marked as protected.  So when a reported was generated, we couldnt change the Text to the correct value, and hense the error message.
