Author Topic: Linking a method on a class to another diagram  (Read 7472 times)
dirc
« on: March 10, 2006, 07:27:04 am »
I posted something on this ages ago, but can't for the life of me find it!
Basically, I would really like to be able to somehow link a method on a class in a class diagram to a sequence diagram which shows how the method works. On the sequence diagram, I'd like to add a link the other way.
Then, when you view the class diagram, you will be able view the sequence diagram for the method then navigate back to the class diagram.
Is this possible, even by devious means?
dirc
Re: Linking a method on a class to another diagram
« Reply #1 on: March 10, 2006, 09:38:09 am »
Place a hyperlink near the class with a reference to the sequence diagram. So you will be able to create more than one reference (your method might appear in more than one diagram).
dirc
« Reply #2 on: March 11, 2006, 02:21:32 am »
I have used hyperlinks on a diagram, but this is not a very elegant solution.
I want to do it on the class itself, so that whatever diagram it appears in, you can navigate to the sequence diagram.
dirc
Bruno.Cossi
« Reply #3 on: March 11, 2006, 05:05:15 am »
a little workaround... create a diagram under the class and set the class as a Composite Element. Place the hyperlinks on the diagram under the class.
This way, whichever diagram the class is on, double-clicking on the class will take you to the kyperlinked diagram.
Hope this helps!
Bruno
jeshaw2
« Reply #4 on: March 11, 2006, 11:57:59 am »
Hope this helps!
Bruno
What do you mean by "create a diagram under the class?".  Does the class element overlay the diagram or does it appear higher on the diagram page?
Can you step me through the process?
« Reply #5 on: March 12, 2006, 06:39:13 am »
I guess, Bruno meant to create the diagram as sub-element of a class (right click class in project view/Add xy Diagram)
Bruno.Cossi
« Reply #6 on: March 12, 2006, 10:59:51 am »
Yes, that's what I meant :-) Thanks, Thomas!
Also, when you set the class as a Composite Element (right-click, them menu Advanced Settings > Composite Element), a diagram underneath the class will automatically be created for you.
Bruno
jeshaw2
« Reply #7 on: March 12, 2006, 03:17:42 pm »
When you say composite element on a class, is that the same thing as a UML composite structure?
« Last Edit: March 12, 2006, 03:18:43 pm by jeshaw2 »
Bruno.Cossi
« Reply #8 on: March 12, 2006, 04:19:28 pm »
No, it is not. Please see my description above.
Bruno
jeshaw2
« Reply #9 on: March 12, 2006, 04:27:59 pm »
Ah!  I missed that..
It is the UML element that is a composite not the class being modeled.
Bruno.Cossi
« Reply #10 on: March 12, 2006, 05:35:35 pm »
Hi Jim
yes, that's it! Sorry for not having been clear on the first place.
Bruno
