Author Topic: Export/Import packages between models  (Read 4007 times)
pmahoney
  • An old picture. More grey now :-(
« on: March 20, 2006, 02:39:44 am »
I'm trying to move a package from one model to another. When I try to import I get:
Error:
Code = 0c00ce014
Source = Line : 367; Char : 218
Error Description = Element content is invalid ccording to the DTD/schema
Expectng: {ULM}ModelElement, {UML}Comment, {UML}Namespace, {UML}GeneralizableElement, {UML}Feature, {UML}Paramater, {UML}Constraint. {....
Re: Export/Import packages between models
« Reply #1 on: March 20, 2006, 02:42:08 am »
Have you looked inside? What do you find at the specified location?
pmahoney
« Reply #2 on: March 20, 2006, 02:55:10 am »
<UML:Device name="Cisco PIX 501" xmi.id="EAID_F9DA9978_73E0_400c_9A87_E4F3D37D69CB" visibility="public" namespace="EAPK_CD98AA0D_EF64_45cb_A6EF_E049FF02139E" isRoot="false" isLeaf="false" isAbstract="false">
Char pos 218 is at the end of the word isAbstract
« Reply #3 on: March 20, 2006, 08:17:21 am »
Looks like a version mismatch or you have the wrong DTD. Check the DTD you are using. If it seems to be correct you should report a bug. In order to import the file though, you should change/ isAbstract="false"// globally in the file.
sargasso
« Reply #4 on: March 20, 2006, 04:51:07 pm »
Or use ex/imp without the DTD turned on!!
pmahoney
« Reply #5 on: March 21, 2006, 01:55:14 am »
Exp with no DTD did the trick.
