Author Topic: "Tagging' or Marking Model Glossary Entries  (Read 3753 times)
lipmanc
« on: March 29, 2006, 11:08:07 am »
I just started using the Model Glossary. Is there any way (via EA feature) to signify or highlight each time a Glossary Term is used within our models/notes.
I know that I can use Proper Case, for example, whenever I use a defined term so that the reader knows that it has special meaning.  Is this up to me, as the user to manually implement or is there some type of feature?
Re: "Tagging' or Marking Model Glossary Entri
« Reply #1 on: April 01, 2006, 10:13:44 am »
The glossary is a simple table with three columns: Name, Note, Type. You could implement more using triggers inside the database. Look at t_glossary (I have no EA here so this might be the wrong name).
