Author Topic: Help shows "page not found"  (Read 3339 times)
J.D. Baker
« on: April 01, 2006, 03:43:50 pm »
When I try to access the help file, either from within EA or by launching the .chm separately, every attempt to view content results in page not found.  I had some instructions for trying to solve this problem but I can't access them from my current location.  Anyone know a good way to attack this problem?
J.D. Baker
J.D. Baker
Unreasonable Technologist
Re: Help shows "page not found"
« Reply #1 on: April 02, 2006, 03:18:20 am »
You can download the PDF or use the online help from Sparx site.
J.D. Baker
« Reply #2 on: April 02, 2006, 05:44:37 am »
Yes I can, but I'd still like to be able to access help from within the application, and the only help that doesn't work seems to be EA.
J.D. Baker
« Reply #3 on: April 02, 2006, 12:30:56 pm »
Not heard of anything similar. Maybe a Windoze issue?
« Reply #4 on: April 02, 2006, 04:23:55 pm »
There is an issue with a Windows security update that stops .chm files being viewed over a network.
Could this be the problem?
Edit: I get 'Action Canceled' in that situation, so it's probably not that.
« Last Edit: April 02, 2006, 04:37:01 pm by simonm »
« Reply #5 on: April 02, 2006, 04:24:51 pm »
There was a Windows security update last June [KB896358] that prevented opening .chm files from network drives. If that's your problem, you can either copy the help file to a local drive or remove the security update.
More info: Microsoft Security Bulletin
« Last Edit: April 02, 2006, 04:25:34 pm by KP »
