Author Topic: Profile import error...  (Read 3016 times)
Inferjack
« on: April 03, 2006, 08:40:47 am »
I have a problem with importing a profile . After I Save as a profile and try to import as a UML profile I get an error with the following description:
Error:
Code=0x0
Source = Line: 0; Char:0
Error Description = (null)
After that there is not possible to open the project ;-(. The same error occures again and again...
Does anybody knows where is the problem?
Many thanks in advance!
Jacek J.
Re: Profile import error...
« Reply #1 on: April 03, 2006, 01:36:03 pm »
Have you tried opening the profile with an editor? What does it contain? Looks like you have an empty file. Or maybe a security issue?
« Last Edit: April 03, 2006, 01:36:35 pm by thomaskilian »
« Reply #2 on: April 03, 2006, 04:24:39 pm »
It might be that required image files don't exist in the same directory as the profile file. Open the profile file in an editor and search for "metafile" to see which image files are required.
If that isn't the case, can you send the profile file to [email protected] and we can investigate further (and maybe provide a more meaningful error message)
Neil
SF_lt
  • The Truth Is Out There
« Reply #3 on: April 04, 2006, 04:05:47 pm »
Also, would like to ask Sparx - if I provide profile, where I provide not only new stereotypes, but also relation constraints for a new stereotypes - would EA validate models against such profile?
registertm everything to SparX
