Author Topic: WMF stereotype not showing on diagram  (Read 5914 times)
mylesJ
« on: February 21, 2006, 04:44:58 am »
I have created a stereotype with a WMF image file. But when I drop the stereotype on to a diagram it does not draw the WMF image.
Do diagrams support WMF? If not then why have WMF at all for stereotypes?
Re: WMF stereotype not showing on diagram
« Reply #1 on: February 21, 2006, 06:38:57 am »
What do you mean by "drop stereotype on diagram"?
mylesJ
« Reply #2 on: February 21, 2006, 07:32:24 am »
I mean create an instance of the object on a diagram. For some reason my WMF image is not showing. If I use the shape language to draw an image then it shows. As soon as I switch to using a WMF image it dissapears.
« Reply #3 on: February 21, 2006, 10:45:14 am »
I used EMF instead in the past. So if there's a reproducable problem with WFM I suggest to file a bug report.
AshK
« Reply #4 on: February 21, 2006, 04:20:34 pm »
Hi Myles,
I haven't been able to replicate the problem here - wmf works fine for me here  :-/
Please do send a bug report, and if you're willing, the particular wmf file that you're trying to display.
Ash
mylesJ
« Reply #5 on: February 21, 2006, 11:17:08 pm »
Thanks for clarifying. I'll try EMF firsg & also log the problematic WMF as a bug.
mylesJ
« Reply #6 on: February 22, 2006, 09:42:40 am »
I have an update on this. The WMF image works fine if I set the stereotype base class to "class". But when I set the base class to "Action" it doesn't display.
Any ideas why this is so? Is it a bug or intended behaviour?
« Reply #7 on: February 22, 2006, 10:11:02 am »
I know that Sparx has added additional element types to those affected by certain Shape Script features (adornments come to mind).
Perhaps the same sort of thing holds true for pictures; they might only be available for specific element types.
Perhaps this is worth your asking for more in the Suggestions forum.
AshK
« Reply #8 on: February 22, 2006, 03:40:05 pm »
Myles,
I've traced your problem back to issue with our Action code.  Please find that the problem has been corrected in our next build, 788 (approx. next week).
Ash
mylesJ
« Reply #9 on: February 23, 2006, 01:42:17 am »
Thanks. I'll look forward to testing it out.
StefanPears
  • Unwissenheit schützt vor Erkenntnis nicht
« Reply #10 on: April 06, 2006, 11:37:35 pm »
Hi all,
now I have build 789 but still I can't assign an alternate image to an action. Same for Stereotypes with Alternate Images.
The upper works fine with activities and lots of other elements.
any ideas?
Stefan
