Author Topic: action script 2 generation  (Read 2694 times)
realien
« on: April 07, 2006, 01:44:22 pm »
Hi guys, I'm new to EA but well versed in UML and tools, we own Togethersoft (now borland)  products and I used rational in my darker days.
I'm running the eval copy of EA and am very impressed so far, I have a flash project I'm building some classes for and as test I created a simple class called EventNames and when EA generated the class I get two class statements in the code :
* @version 1.0
* @created 07-Apr-2006 4:37:02 PM
class Class Model.com.iLearn.util.EventNames
}//end EventNames
notice the class Class ?
Is there a patch/fix I need to do so I don't have to correct every generated file.
I was also looking for a way to reverse engineer a method on a class into a sequence diagram as i often do in java with Borlands Enterprise Architect Tool.  Is this possible with EA ?  I could find anything that would let me select a method and then choose "generate sequence diagram"
Grant
http://www.bluetube.com
http://theresidentalien.typepad.com
Re: action script 2 generation
« Reply #1 on: April 09, 2006, 03:04:11 pm »
Hi Grant,
You need to set your 'Class Model' package as a namespace root.  To do this right click on it in the project view and select Code Engineering | Set as Namespace Root.
EA will generate a namespace for each package below a namespace root package.
Please see http://www.sparxsystems.com.au/EAUserGuide/index.html?namespaces.htm for more information.
