Author Topic: Scenario's and Documentation Generation  (Read 4381 times)
Bokkie
  • Lima Bravo!
« on: April 10, 2006, 12:22:54 am »
I'm having a little problem getting the scenario's of use cases in my documention. The following is my model structure:
<model>
 <package>
   <activity>
     <activity>
       <Use Case>
       <Use Case/>
     </activity>
   </activity>
 </package>
</model>
The Use Case contains scenario's. The standard basic template does not output the scenario's (root for generation is a top level activity. When I select the Use Case as root, the scenario is outputted. I've played around with the template but nothing gives me the scenario....
Any ideas?
Lima Bravo!
Re: Scenario's and Documentation Generation
« Reply #1 on: April 10, 2006, 01:23:31 am »
Unfortunately I have no idea regarding the documentation. I'm just curious why you place Use Cases inside Activities. I would expect it to be the other way around. ???
sargasso
« Reply #2 on: April 10, 2006, 04:35:53 pm »
For activity read business process???
b
colinc
« Reply #3 on: April 10, 2006, 05:35:14 pm »
I use virtually the same structure (with business processes at the top level, which are only stereotyped activities).
I couldn't get the output to work from the standard basic template, but it is relatively OK if you make a new template by copying the Basic template it isn't too bad.
I use the following structure in my template:
It takes a bit of playing to get what you want out of the template generator.
Good luck!
{Diagram.Name}
{Diagram.DiagramImg}
Figure:{Diagram.Figure}: {Diagram.Name}
< diagram
element >
{Element.Name}
{Element.Notes}
scenario >
Flow of Events
{ElemScenario.Type}
{ElemScenario.Scenario}
{ElemScenario.Notes}
< scenario
< element
child packages >
< child packages
< package
Bokkie
  • Lima Bravo!
« Reply #4 on: April 10, 2006, 11:43:43 pm »
b
Exactly!
Lima Bravo!
« Reply #5 on: April 11, 2006, 05:05:08 am »
Exactly!
Makes sense :)
Bokkie
  • Lima Bravo!
« Reply #6 on: April 12, 2006, 12:09:41 am »
Ok, I've got it working finally. Their seems to be a little bug:
When recursivly iterating elements and child elements the scenarios and requirements are not reported for child elements.
When recursing via diagrams the scenarios are reported.
M.
Lima Bravo!
« Reply #7 on: April 12, 2006, 12:14:09 am »
OK, I've got it working finally. Their seems to be a little bug:
When recursively iterating elements and child elements the scenarios and requirements are not reported for child elements.
M.
Don't forget to report the bug through the official channels...
Bokkie
  • Lima Bravo!
« Reply #8 on: April 12, 2006, 12:21:18 am »
Done.
Lima Bravo!
