Author Topic: export stereotypes with appearance  (Read 3320 times)
Bokkie
  • Lima Bravo!
« on: April 13, 2006, 12:42:47 am »
Hello gurus!
EA allows export and import of stereotypes from one model to another. However, the stereotype appearance (e.g. color) is not imported/exported? I'm using the Tools->Import/Export Reference Data function.
M.
Lima Bravo!
Bokkie
  • Lima Bravo!
Re: export stereotypes with appearance
« Reply #1 on: April 13, 2006, 12:47:50 am »
Addendum: The appearance is imported (Settings->UML->Stereotypes), however it is not applied somehow  ???
Lima Bravo!
« Reply #2 on: April 13, 2006, 03:18:59 am »
Bookie,
I have recently applied customized colour settings (only) to several new stereotypes (versus changing the colour of those that were already there, which I simply have not tried).
I did this in two models (one in an EAP file, one in a repository) and somehow managed to set the colours differently. Flipping between the models was a bit jarring.
This gave me the occasion to export from one model and import into the other. Worked like a charm, and suddenly (instantly) the colours were the same in both.
So, I don't know about whether this would work for pre-existing stereotypes, or for settings outside of colour, but I got the colour part working the first time. Check to make sure you did just what you think you did - just to make sure it was not 'finger trouble. It should work.
