Author Topic: Error with the EAP file  (Read 2380 times)
tapan
« on: April 26, 2006, 05:32:23 pm »
 :'( . I have designed a data model using Enterprise Architect. It was working absolutely fine.
I clicked on project--> Version control and added to VSS.
Ever since I added to VSS I am not able to open the file at all.
It is giving an error saying
An Error occured: The Microsoft Jet Database Engine cannot open the file. It is already opened by user exclusively  or you need permission to view the data
Please help
Re: Error with the EAP file
« Reply #1 on: April 27, 2006, 03:38:08 pm »
EA needs to open the file as read-write.  Check that you have the proper permissions.
Also, it sounds a bit like you've tried checking your eap file into version control.  That is far from an ideal situation.  EA supports checking packages from a model in.  It may be worth reading the whitepaper on Version Control in EA if you haven't already.
http://www.sparxsystems.com.au/WhitePapers/Version_Control.pdf or Whitepaper Repository
