Author Topic: Adding notes to return type of a method  (Read 2152 times)
bradmcnutt
« on: May 01, 2006, 02:51:48 pm »
I see how you can add notes to a method or to the params in a method but is there anyway to add notes to the return type of a method so that the <returns>...</returns> xml comment block is generated when you generate the code of your method?  Thanks in advance.
sargasso
Re: Adding notes to return type of a method
« Reply #1 on: May 01, 2006, 04:03:35 pm »
Guess: try using @returns as a tag in the method notes.
Create a simple class with a ///<remarks> doc item and reverse engineer it to see what I mean.  I dont know if it works for methods though.
hth
bruce
