Author Topic: Code import problem with __stdcall  (Read 3287 times)
dominique
« on: April 29, 2006, 03:31:25 pm »
I have a problem with the code import from C++ code.
There is a parse error in EA if i use __stdcall in my C++ code.
The hint in EA is:
You may need to define a language macro
But what can I do? What should the macro look like?
Thx
Dominique
« Last Edit: April 29, 2006, 03:34:02 pm by dominique »
Re: Code import problem with __stdcall
« Reply #1 on: May 02, 2006, 03:04:53 am »
I'm not a C++ guy, but you can define a list of macros which you are using in your code to make EA aware of them: Settings/Preprocessor Macros.
« Reply #2 on: May 03, 2006, 03:30:48 pm »
Thomas is correct in his interpretation of this message.  The help page http://sparxsystems.com.au/EAUserGuide/index.html?languagemacros.htm talks more about this and what sort of macros can be skipped.
However, the __stdcall macro should be skipped even without defining a macro for it there.  (And it is for me)  Are you sure that it is __stdcall that is causing your problem?
dominique
« Reply #3 on: May 03, 2006, 03:54:13 pm »
#ifndef CAMERA_H
#define CAMERA_H
#define cdSTDCALL __stdcall
namespace dom
class Camera
public:
Camera();
virtual ~Camera(void);
static cdUInt32 __stdcall function1(int i);  // OK
static cdUInt32 cdSTDCALL function2(int i);  // not OK
#endif
You are right Simon. The problem is not __stdcall. I figured it out as i wrote the test-class above.
The Problem is that EA checks the source code without pay attention  the preprocessing.
Any proposals?
Thx
Dominique
« Reply #4 on: May 03, 2006, 03:56:12 pm »
Read the help link I posted before and add cdSTDCALL to the macro list.
dominique
« Reply #5 on: May 03, 2006, 04:22:38 pm »
Thank you Simon. But this is not very elegant. I dont have only one macro.
Conclusio: It would be nice if this would be done automatic by EA in the next releases, if possible.
Dominique  :)
