Author Topic: ODBC Schema Import problem  (Read 2370 times)
mylesr
  • Howdy!!
« on: May 08, 2006, 10:14:11 am »
I tried importing a rather large database schema and it appeared to work successfully, meaning that in the Project View I could seee the list of tables that had been imported in the "Model" folder.  I noted that the "save" button was greyed out, so I assumed that evrything was saved and I closed EAP.  (The .eap file was 10MB, also indicating that quite a bit of data had been imported.)  When I reopened the project, the Model folder was empty.  I tried reimporting the schema but now the "Model" folder is empty even before I close the project.  Help!
mylesr
  • Howdy!!
Re: ODBC Schema Import problem
« Reply #1 on: May 08, 2006, 01:16:05 pm »
I found the problem.  The import option was set to "synchronize existing" instead of "create new".  Since there were no existing tables to synchronize with, it went through all the motions, but accomplished nothing.
