Author Topic: MySQL Question  (Read 3337 times)
amti
MySQL Question
« on: February 22, 2006, 09:38:46 am »
The MySQL database I'm developing uses both InnoDB and MyISAM tables.
I see that the EA docs say to use a different source database for each type.
I'm new to EA, and I want to make sure that it's possible to include both types in one database model before I proceed with setting everything up.
Thanks!
Bruno.Cossi
Re: MySQL Question
« Reply #1 on: February 22, 2006, 09:42:23 am »
you can make each of the tables you design based on a different DBMS, you could even create one table as MySql one, another as Oracle and yet another as Sybase.
Hope this helps!
Bruno
Thanks!
Re: MySQL Question
« Reply #2 on: February 22, 2006, 10:33:27 am »
For InnoDB you have to specify a Tag for the table: Type="InnoDB"
rneelakantan
Re: MySQL Question
« Reply #3 on: May 09, 2006, 04:41:54 pm »
I have a similar issue in setting type=InnoDB.  Even after creating Tag (right click on table ->Add ->Add Tagged Value and setting type=InnoDB, I don't see the type set in the generated DDL.  Any suggestion?
Re: MySQL Question
« Reply #4 on: May 10, 2006, 12:32:38 am »
Check the case: Type, not type
rneelakantan
Re: MySQL Question
« Reply #5 on: May 10, 2006, 03:15:36 pm »
It worked but not on the first attempt.  I had Type set to InnoDB (capital T in Type).   But it did not work, so I had to delete it, close EA and then open EA and then re-created.  It worked.
Thx.
Ramanan
Re: MySQL Question
« Reply #6 on: May 11, 2006, 02:11:29 am »
Thanks for the feedback :)
