Author Topic: need a dll  (Read 2969 times)
ajc
need a dll
« on: May 14, 2006, 10:11:15 pm »
I have installed EA on a windows 2000 (SP4) and it won't run. It presents with an error saying
"an incorrect version of MSJET35.dll was found" when I look this up (in /system32) it is version 3.50.3602.4
there is also a newer MSJET40.DLL in the library
any help would be much appreciated
ajc
Re: need a dll
« Reply #1 on: May 15, 2006, 03:24:01 am »
Ajc,
It seems as if Windows is not recognizing its own Jet drivers for some reason.
First thing to try is this: if you can get EA up at all, from the start menu rather than by clicking on an EAP file, use the main menu to open the Tools / Options dialog. Check the "Use Jet 4.0 - requires restart" box, close EA, and restart. See if this resolves your problem.
If the above does not work, you may be able to register the driver you have by running regsvr32 from the command line, but I cannot say for sure if this could have other effects.
Another option may be to install a recent version of MDAC. The most recent versions (since about 2.6 or 2.7, but I don't remember for sure) do not contain the Jet drivers, but they may set them up for you if they are there. You might be able to find an earlier version and install that.
Finally, you could install a recent (perhaps since "97") version of Access, or perhaps even Office or Excel or Project (which may install Jet drivers).
If the above don't work at first, keep watching for replies on this thread, since the Sparx folks and other users have probably seen this at some time.
HTH, David
ajc
Re: need a dll
« Reply #2 on: May 15, 2006, 06:16:14 pm »
Setting the option to use Jet 4 resolved the issue. Much obliged for the quick response
kind regards
ajc
