Author Topic: Capture output  (Read 2212 times)
xirtam
Capture output
« on: May 18, 2006, 12:09:49 pm »
I do have a problem capturing the output of my compiler .
I have a build script like this.:
"C:\Program Files\Microsoft Visual Studio .NET 2003\Common7\IDE\devenv.exe" MyProject.sln /build Debug
When I run it from within EA I can see the message :
Running build script - My Dev MyProject
Build completed with exit code 0
So the project has been build but I’m not able to see compilation output .
Is there any special settings I have to do ?
Thank you
Marcello
Re: Capture output
« Reply #1 on: May 18, 2006, 03:13:45 pm »
Try using devenv.com instead of devenv.exe, I think that the exe version doesn't give output to the command line in the normal way.
