Author Topic: import *  (Read 14691 times)
Andrefern
import *
« on: May 18, 2006, 06:00:01 am »
I'm trying to define a dependency relation between a class and a package (package1) as import. I'd like to generate code of this class with:
import xxx.xxxx.xxxx.package1.*
But it haven't worked. Have I done something wrong?
Thanks.
Re:  import *
« Reply #1 on: May 18, 2006, 06:42:52 am »
You should mention the language you're using...
Andrefern
Re:  import *
« Reply #2 on: May 18, 2006, 06:54:29 am »
Java
Re:  import *
« Reply #3 on: May 18, 2006, 07:06:56 am »
Is this something of your own design - a part of your model - that needs to be imported somewhere else? Or, are you attempting to import a part of the Java environment?
In the latter case you'll have to use EA's Import Binary Module to bring the Java environment into your model somewhere. There is a lot of info here in the forum on how to do that, so try a search.
Andrefern
Re:  import *
« Reply #4 on: May 18, 2006, 07:12:19 am »
This package is from my own design. But, if it were from some package in Java Environment I would like to do the same.
I don't like verbose imports. Anyway, it's a good pratice use import *.
Re:  import *
« Reply #5 on: May 18, 2006, 07:17:13 am »
But difficult for EA and other tools to interpret.
Re:  import *
« Reply #6 on: May 18, 2006, 03:11:18 pm »
If you really want to do this, then you're going to need to add a list over connectors in your import section template.  Add as a condition in the list that the source needs to be the current element, the target should be a package and the connector type should be a dependency.
Sorry, I can't give a code fragment that would do it at the moment.
Andrefern
Re:  import *
« Reply #7 on: May 19, 2006, 11:42:06 am »
Ok.
Thanks for your answers.  ;)
