Author Topic: PostgreSQL and CONSTRAINT UNIQUE  (Read 10719 times)
marcusmolin76
« on: May 19, 2006, 10:57:43 am »
I'm using EA 6.1.789 to visualize the schema of a PostgreSQL
database.
I'd like to add a UNIQUE constraint to one of the tables,
which would be an euqivalent of
CREATE TABLE user_station
 id int4 NOT NULL DEFAULT nextval('user_station_id_seq'::regclass),
 user_id int4 NOT NULL,
 station_id int4 NOT NULL,
 CONSTRAINT user_station_user_id_key UNIQUE (user_id, station_id)
This table's PK is the "id" column, and both "user_id" and "station_id" are unique together.
Is there any way I can achieve with EA?
Thanks!
hd
Re:  PostgreSQL and CONSTRAINT UNIQUE
« Reply #1 on: May 21, 2006, 03:25:14 pm »
  • Add an operation called "user_station_user_id_key" (select table and press F10) and select "unique" as it's sterotype. Save.
  • Select operation, select "Columns" tabe, and select the required columns from the Column Name: drop down.
