Author Topic: ShapeScript commands & Samples  (Read 4240 times)
nara_c
« on: May 01, 2006, 08:01:08 pm »
Hi All,
Since there is a number of questions related to shapescript and the help file in EA is not yet up to date, I thought it would be a good idea if we all post our ShapeScript secrets here for other to benefit from.  The following post contains hidden shapescript commands that I determined from contacting Sparks Support.
Hope this helps.
/* SAMPLE TEMPLATE- Creates a Bordered note
  with text from the Element Notes field*/
shape Default
       noshadow = true;
       layouttype="border";
       moveto(50,0);
       lineto(0,0);
       lineto(0,100);
       lineto(50,100);
//Add Subshapes
       addsubshape("padding","W");
       addSubShape("line","CENTER");
//Padding Shape definition
       shape padding
               preferredwidth=5;
//Text Shape definition
       text line
               PrintWrapped("#NOTES#");
/* More COMMANDS to access element property fields
  The #NOTES# part will retrieve the notes
  attribute from the instance that it applies to.
Other Symbols for nodes are:
name
scope
type
classifier
propertytype
stereoType
alias
language
complexity
version
phase
language
packageName
author
status
keywords
isTagged
isAbstract
multiplicity
isroot
isleaf
isSpec
isActive
persistence
notes
cardinality
visibility
concurrency
isEmbedded
isLocked
parentEdge
For paths:
name
direction
type
stereotype
source.multiplicity
target.multiplicity
source.aggregation
target.aggregation
source.multiplicityisorded
target.multiplicityisorded
source.changable
target.changable
source.constraints
target.constraints
source.qualifiers
target.qualifiers
source.targetscope
target.targetscope
source.stereotype
target.stereotype
isroot
isleaf
notes
subtype
/* WITH CONDITIONAL SUBSHAPES - SAMPLE SHAPESCRIPT
  (from BPMN notation)*/
shape BPMNActivity
startpath();
roundrect(0,0,100,100,10,10);
endpath();
fillandstrokepath();
if(HasTag("IsATransaction","true"))
roundrect(2,3,98,98,10,10);
addsubshape("base","S");
addsubshape("padding","N");
addsubshape("padding","E");
addsubshape("name","CENTER");
text name
h_align = "center";
PrintWrapped("#NAME#");
shape padding
preferredHeight=10;
preferredWidth=10;
shape base
preferredHeight=20;
addsubshape("null","N");
addsubshape("null","S");
addsubshape("baseshapes","CENTER");
shape null
preferredHeight=3;
shape baseshapes
layouttype="leftright";
scalable=false;
v_align="CENTER";
h_align="CENTER";
addsubshape("spacer");
if (HasTag("LoopType","Standard"))
addSubShape("loop");
if (HasTag("LoopType","MultiInstance"))
if (HasTag("IsMultipleInstance","true"))
addSubShape("multiple");
if (HasTag("IsCompensation","true"))
addSubShape("compensation");
if (HasTag("ActivityType","Sub-Process"))
addSubShape("collapsed");
if (HasTag("AdHoc","true"))
addSubShape("adhoc");
shape spacer
preferredWidth=2;
shape loop
preferredWidth=10;
preferredHeight=10;
setpenwidth(2);
moveto(70,90);
arc(0,0,100,100,70,90,30,90);
//moveto(60,100);
//arc(0,0,100,100,60,100,40,100);
setfillcolor(0,0,0);
startpath();
moveto(-20,100);
lineto(40,100);
lineto(40,60);
endpath();
fillpath();
shape multiple
preferredWidth=10;
preferredHeight=10;
startpath();
rectangle(10,0,40,100);
endpath();
startpath();
rectangle(60,0,90,100);
endpath();
shape compensation
preferredWidth=10;
preferredHeight=10;
startpath();
moveto(0,50);
lineto(50,0);
lineto(50,100);
endpath();
startpath();
moveto(50,50);
lineto(100,0);
lineto(100,100);
endpath();
shape collapsed
preferredWidth=10;
preferredHeight=10;
rectangle(0,0,100,100);
moveto(15,50);
lineto(85,50);
moveto(50,15);
lineto(50,85);
Shape adhoc
preferredWidth=10;
preferredHeight=10;
SetPen(0,0,0,3);
MoveTo(0,50);
StartPath();
PolyBezierTo(50,0,50,100,100,50);
EndPath();
StrokePath();
/* SHAPE DECORATIONS - Those little images that
  appear on the top right of elements.
  This example adds a pale yellow rectangle in
  the top-right corner of an element*/
Decoration Test
Orientation="NE";
SetFillColor(255,255,200);
StartPath();
Rectangle(0,0,80,100);
EndPath();
FillAndStrokePath();
/* EXPLANATION FOR DECORATION COMMANDS:
  The orientation command positions the decoration
  according to compass position. Valid values
  are N, S, E, W, NE, NW, SE, SW and CENTER.
  The rectangle command works with percentage
  values. Decorations are a fixed size so this
  script draws a rectangle the full height but
  80% of the width of a full-sized decoration.
  The startpath, endpath and fillandstrokepath
  commands when used together will fill whatever
  is drawn between the start and end with the
  defined fill colour (which is defined as a
  standard RGB value).
  Shape scripts can have conditional logic based
  on most of the properties of the chosen element,
  and there's a large variety of drawing commands
  available.*/
Dave_Bullet
Re: ShapeScript commands & Samples
« Reply #1 on: May 22, 2006, 08:51:53 pm »
HasProperty("Property","Value")
can be used to test one of the standard properties on a classifier (ie. like Alias, Status etc...).  Similar to HasTag() which can be used to test a tagged value.
