Author Topic: java String, Integer, Double etc  (Read 11144 times)
Re: java String, Integer, Double etc
« Reply #15 on: May 23, 2006, 10:08:24 am »
Something like that Gary,
There's been some discussion here in the forum on this. I don't work with Java much, so I won't try to advise on the best way to divide it up. Do a search on the forum.
You'll have to be fairly patient with the search function. It takes some getting used to, plus both determination and luck to pick the right words. Still, it is worth the time - you will probably find some useful hints in less time that it took to import rt.jar.
Gary W.
« Reply #16 on: May 23, 2006, 10:43:38 am »
David,
Yes, you're 100% correct.   I now see the many threads that address this topic (most with your input =8^).
I had tried searching on "java attribute type int Integer", but using "java import" is much more precise.
Sigh.. it's so much easier to know the exact search terms once you know the answer!
Thanks again,
gary
