Author Topic: Linked Documents  (Read 2146 times)
osmid
Linked Documents
« on: May 24, 2006, 09:39:21 am »
I like the functionality "Linked document" and I would like to ask:
1. It is possible to drag&drop element from Project View to document. Link with name appears. If I modify name of the object - name stays unmodified in the document.
Is it a way how to "refesh" the name in the link?
2. Generating the rtf document the links mentioned above goes to "non-existing" files.
3. Is a way how to attached this "Linked documents" to HTML documentation automatically in generation process?
Thank you
Ota
Re: Linked Documents
« Reply #1 on: May 24, 2006, 10:31:15 am »
Ota,
To the best of my knowledge:
  • There is no way to refresh the document automatically. The document creation function within EA is simply an editor; it is detached once you save the document.
  • For the same reason, a broken link is not automatically detected or corrected. You will have to take care of this yourself.
  • Not at present, or at least not with any flexibility. This has been discussed in this forum over the last several months. Try a few searches (a given set of search terms might not pull all the references, so you may have to try several times) and read through some of the insights. Doing this may also give you some ideas of what to ask for in the way of future enhancements.
