Author Topic: Format Toolbar - Styles -- HELP!  (Read 4563 times)
« on: May 25, 2006, 02:25:48 am »
Can some kind soul explain how the Format Toolbar works?  I've looked in the Help, but I still can't make it work reliably...
I'm interested in defining styles and applying them.  I've created some styles and can apply them some of the time, at other times it seems to not work.
It seems I can't set fonts with the style.  Is that correct?    :'(
TIA,
sargasso
Re: Format Toolbar - Styles -- HELP!
« Reply #1 on: May 25, 2006, 04:23:16 pm »
When you create a style it asks whether you want to make it a font or a paragraph style.
ooops hang on.  Are you talking about linked documents here?
b
« Reply #2 on: May 25, 2006, 04:39:18 pm »
b
No... The Toolbar you get when you use Toolbars | Format Tool
« Last Edit: May 25, 2006, 04:39:32 pm by PaoloFCantoni »
sargasso
« Reply #3 on: May 25, 2006, 05:10:19 pm »
 :-X  Never knew that existed!
No it doesn't seem to apply font appearances, does it.
b
AshK
« Reply #4 on: May 25, 2006, 05:32:21 pm »
Here's what I know:
There are 3 sets of appearance properties:
 -one set for each diagram shape
 -one set for each model element
 -and a standard set (Tools->Options->Standard Colors)
Appearance styles cascade in the order: diagram shape, model element, Ea standard colours.
The renderer will transend to the next set if a property is set to "default".
The Format Toolbar modifies the appearance settings for the diagram shape, where as the Element->Appearance->Configure Default Appearance operates on the model element.
Ash :)
AshK
« Reply #5 on: May 25, 2006, 05:41:18 pm »
The Font setting is part of the diagram shapes appearance settings, however can't be set using the format toolbar and is not incorporated with styles.
It can be set in the shapes context menu (Appearance->Set Font).
« Reply #6 on: May 25, 2006, 09:26:47 pm »
We need Text based styles also...
« Reply #7 on: May 25, 2006, 09:39:35 pm »
Here's what I know:
The renderer will transcend to the next set if a property is set to "default".
Ash :)
How does modify work?  When I select Modify Current Style, nothing seems to happen?
AshK
« Reply #8 on: May 25, 2006, 10:24:32 pm »
It seems the Modify command saves the current values of the Format toolbar to an existing style specifed by the style combobox.  I guess the menu item could have been called "Save".
Ash
« Reply #9 on: May 25, 2006, 10:53:55 pm »
Ash
Should have been called Save.
Please rectify...
AshK
« Reply #10 on: May 25, 2006, 11:32:47 pm »
Please rectify...
Indeed.  Please find the enhancement in 6.5.
