Author Topic: Java local classes  (Read 2492 times)
BusDriver
  • You're either on the bus, or ....
Java local classes
« on: June 03, 2006, 09:59:23 pm »
Are they supported? The following code when reversed only shows method testee - class local is nonexistent. :'(
public class Test {
public void testee(){
class local{
Re: Java local classes
« Reply #1 on: June 04, 2006, 03:16:02 pm »
EA doesn't reverse engineer anything from inside method bodies, so I think you're out of luck.
SF_lt
  • The Truth Is Out There
« Reply #2 on: June 05, 2006, 12:18:43 am »
there could not strict UML way:
put dependencies from owning class (owning method) to local variable class with the <<localVariable>> stereotype
method parameters could be identified by dependencies with <<methodArgument>>, <<constructorArgument>> stereotypies
These are only my thoughts - and could be the subject of discussion
registertm everything to SparX
