Author Topic: How to restore lost properties pane?  (Read 6894 times)
abcoates
  • I love YaBB 1 Gold!
« on: June 09, 2006, 03:00:45 am »
I've lost my EA properties pane [build 790].  I may had accidentally dragged it somewhere (off-screen?), but it isn't there now.  It's selected in the "View" menu, but it won't let me deselect it.  Nothing I've tried has restored it.  Anyone have any suggestions?  Or should I just re-install EA?  Thanks a lot in advance for any help,
Cheers, Tony.
Re: How to restore lost properties pane?
« Reply #1 on: June 09, 2006, 03:51:00 am »
I'd first increase the screen density (even if lower colours) in the hope of actually finding the pane.
Unfortunately EA's unique interface doesn't present the usual Windows interface of [Alt-Space] providing access to the Window mini-menu that includes the Move capability.  You might have been able use this to attempt to bring the pane back into view using arrow keys...
[Edit: [Alt-e] amended to [Alt-Space] above - Simon's later post will no longer make sense - aonther window must have popped up while typng and the spell checker didn't pick up the error]
« Last Edit: June 12, 2006, 04:08:14 pm by PaoloFCantoni »
« Reply #2 on: June 12, 2006, 03:23:16 pm »
I'd try resetting the layout to the default.  (View | Visual Layouts | Default Layout)  That usually fixes layout issues.  Re-installing is unlikely to work unless you're also upgrading to a version that includes new docked windows.
By the way Paolo, [Alt-e] does the same thing in EA as just about every other windows program I can think of, open the edit menu.  I can't think of any standard for opening a mini-menu for dockable windows, via keyboard or not.
« Reply #3 on: June 12, 2006, 04:13:10 pm »
Apologies, Simon, I've corrected the error in my original post, it should have read [Alt-Space] not [Alt-e].  Your point that there is no standard, is taken, but since EA doesn't implement [ALT-Space], there's not much pointing asking about the interior windows.
I would argue that each undocked window should be able to be moved with the windows movement keys.  In fact, the [Alt-Space] standard should include the Home key moving the top left of the windows to the top left of the screen so it would return the window to a known place.
