Author Topic: Deleting links in Use cases - Not working on CVS  (Read 2543 times)
vineetgogia
  • Find a way or make one!
« on: June 13, 2006, 11:31:47 pm »
Our EA model is version controlled and used by multiple users across different locations.
While addition of associations (or other links) in a Use case diagram is reflected to other users, the same is not happening on "Deletion" of use case relationships.
So when the associations are deleted on a use case diagram and changes "checked in" the change is not reflected on other users' model (on get Latest).
Is this a known Bug? or something we might be missing
Re: Deleting links in Use cases - Not working on C
« Reply #1 on: June 13, 2006, 11:58:29 pm »
Are you sure you deleted the Association from the model or only the diagram.  EA's unique user interface can be confusing on this point...   ::).  Each user can set up the action of various key combinations so that the same key combinations may have different effects on different machines.
I now have my settings set so that if I delete either a shape or a connector from the model, EA will ask me to confirm.  That way I know what the actual state of play is...
vineetgogia
« Reply #2 on: June 14, 2006, 02:12:42 am »
This is what I tried
Select the association to be deleted -> "Del" key ->  "Remove connector" popup appears -> Delete the connector from the model and checkin.
get Latest from another machine. Association "Deleted" on other machine still appears.
Thanks for your help
