Author Topic: transformation Class diagram -> DDL  (Read 4030 times)
Martin32
« on: February 14, 2006, 07:36:13 am »
In class diagram I have two classes:
Book { title:string; author: Person; editor: Person }
Person {name:string }
and
associations:
Book.author -> "Person"
Book.editor -> "Person"
After transformation to DDL a received this tables:
Book ( (PK)bookID: integer;  (FK)PersonID:integer; title:string );
Person ( (PK) PersonID:integer; name:string)
and two same relations:
Book.PersonID -> Person.PersonID
Book.PersonID -> Person.PersonID :(
I lose author/editor information. What do I wrong?
Re: transformation Class diagram -> DDL
« Reply #1 on: February 15, 2006, 02:33:14 am »
Enter "foreign key" in the Help search. Read the third section (DDL Transform...) to see an example.
Martin32
« Reply #2 on: February 15, 2006, 03:36:45 am »
I have already seen it but there is not "double association" in this exmaple.
« Reply #3 on: February 15, 2006, 03:48:27 am »
Because the primary key is created automatically and of type INTEGER. Your relations ar of type Person. It's not possible to map the foreign INT-key to person. Ergo, you have to manually work on the translation.
cnj_mike
« Reply #4 on: June 19, 2006, 11:18:40 am »
I'm using PK/FKs of type INT and I have the same problem.  I have two members of class Component as FK to class Item.  My intention is
CLASS Component
 FK container_id  (containerId=itemId)
 FK component_id (componentId=itemId)
but no joy.  Any way to transform the PIM to a DDL without having to write my own transform code?  Seems like a common need.
« Reply #5 on: June 19, 2006, 11:56:24 am »
Double FK does not work (yet). I hardly remember having read something that 6.5 will be able to deal with that...
« Reply #6 on: June 19, 2006, 12:26:10 pm »
Sparxians,
Don't forget you'll need to support multiple foreign keys with overlapping columns...  That is, a given column in a table may participate in more than one foreign key simultaneously.
As reported elsewhere in this forum, other products have difficulty with this.
