Author Topic: Importing c++: no assocs from pointer member vars?  (Read 3131 times)
Gus
« on: June 15, 2006, 03:45:29 am »
Hi all,
I'm evaluating Enterprise Architect (6.1.791) and I've hit a bit of a problem importing existing c++ code. Any help would be much appreciated.
If I import b.h and a.h:
class b
class a
 b m_b;
.....I see what I would expect on the class diagram, ie an association between a and b, with the target role set to m_b. However, if I change a.h to:
class a
 b* m_pb;
.....and import the code again I don't get the association drawn any more.
In other words, pointer member variables don't generate associations. Should they? Can they?
Gus
Re: Importing c++: no assocs from pointer member v
« Reply #1 on: June 15, 2006, 07:01:36 am »
Gus,
Just to be clear what you're asserting...
The first example should be an Association by value and the second an Association by reference, correct?
Gus
« Reply #2 on: June 15, 2006, 07:08:48 am »
Hi Paolo,
I'm new to UML but yes, I believe that's correct.
Gus
« Reply #3 on: June 18, 2006, 03:15:26 pm »
Hello Gus,
EA reverse engineering currently only creates associations when the attribute type exactly matches the class name.  Because that attribute is a pointer, the pointer is included in the type and no association is created.
SF_lt
  • The Truth Is Out There
« Reply #4 on: June 28, 2006, 10:56:14 am »
That's bad
registertm everything to SparX
