Author Topic: Network error on deleting package  (Read 4145 times)
CapJo
« on: June 07, 2006, 01:44:40 am »
I'm using EA 6.1 Build 790 with a local PostgreSQL 8.1.4 repository.
The configuration of the ODBC-Driver is the same as shown in this manual
http://www.sparxsystems.com.au/EAUserGuide/index.html?setupapostgresqlodbcdriver.htm
The repository works well. Only if i try to delete a package or class an error occours -
"Enterprise Architect has experienced a network error and will close down."
Deleting operations and attributes works without this error.
What's going wrong? I thougth about missing permissions in PostgreSQL but I have granted all permissions to my User-Account.
I can't find the reason for this error.
Can someone give me an advice?
I worked out that this problem occurs only on access from my pc to my local repository. Frome a remote host you can access the repository without problems.
« Last Edit: June 07, 2006, 04:15:34 am by CapJo »
Re: Network error on deleting package
« Reply #1 on: June 08, 2006, 12:11:11 am »
Just a rough guess: do you have the correct GRANT to delete (don't know whether you can do that with Postgres)?
Broszeit
« Reply #2 on: July 06, 2006, 07:00:48 am »
Is there already a solution?
We have the same problem and the user is already superuser and database owner. I think this means he has all privileges.
It would be nice if someone can help us.
« Reply #3 on: July 06, 2006, 08:59:11 am »
There is a fix listed for build 791 that has to do with deleting packages under version control under some circumstances. You might want to check it out (no pun intended).
alesliehughes
« Reply #4 on: July 06, 2006, 07:21:59 pm »
I had a simular problem when using Postgres 8.1.4.
All I did was upgrade the driver to 8.02.0002 and the isssue went away, but your mileage may vary.
You can download the file from
http://pgfoundry.org/frs/?group_id=1000125&release_id=546
If after the upgrade, you are still having problems please email support with the issue.
Alistair
