Author Topic: Import DB Schema from ODBC  (Read 4726 times)
rknr55
« on: February 21, 2006, 11:53:07 am »
I tried importing a db schema using ODBC...I'm getting a 'Internal error - unable to initialize NLS during driver load'.
Here is what I did:
1) I used Oracle 10g Instant client to create a datasource (from Windows XP).  The data source was successfully created -- i could 'test the connection' without any problem.
2) Now, when I went to EA and tried importing, I got the foll above error message
3) I tried the same thing with Oracle client (not the instant client), I got the same error.
Any help will be highly appreciated.
hd
Re: Import DB Schema from ODBC
« Reply #1 on: February 21, 2006, 02:14:26 pm »
Use Windows "ODBC Data Source Administrator" to create the ODBC datasource.
rknr55
« Reply #2 on: February 21, 2006, 02:55:07 pm »
That is what I used (Control Panel->administrative tools->ODBC Datasource).   I got the above issue
« Reply #3 on: February 22, 2006, 01:00:07 am »
Your ODBC driver seems to be in trouble. Try to verify that it is the right one. Try accessing the source with Excel (import external data) for test purpose.
ochrzan
« Reply #4 on: July 10, 2006, 10:49:37 am »
I am getting the same error. I can access the database fine through excel. I am using the 10.2.0 client. Not sure why this is failing.
Dave_Bullet
« Reply #5 on: July 10, 2006, 09:54:23 pm »
I don't know if this helps, but I'm using the following to reverse engineer an Oracle 9i (?) DB with no problems:
- Win XP Professional SP2
- ODBC driver manager V3.525.1117.0
- Oracle 9.02.00.00 ODBC driver (SQORA32.DLL 2002-03-12)
- EA 6.1.790 Corp edition
Cheers,
David.
