Author Topic: Can we get business logic?  (Read 2620 times)
kkonathala
« on: July 11, 2006, 02:19:13 am »
   I am a newbie, i have downloaded and installed EA and want to create a model for java application. I have gone through the tutorial..
1. Can we get the business logic from model. If yes kindly give me the suggestions to go ahead.
2. In the Project browser we have different models like Business process model,usecase model, etc.. We have to follow the structure in that manner or can we create our own package structure.
Thaniking you in advance
Kalyani
Re: Can we get business logic?
« Reply #1 on: July 11, 2006, 06:25:06 am »
Hi Kalyani,
You can create your own project tree, organizing it as you wish. You must have at least one project root, which is always present. You also have to have a set of views under the root. These are just the packages directly under the root, which EA treats a little differently in a small number of cases. You can assign each view one of the icons EA provides - you will see a dialog when you create the view.
I'm not quite sure what you mean by "business logic" in your context, so I will not attempt to answer that now.
kkonathala
« Reply #2 on: July 11, 2006, 09:19:47 pm »
   ThanQ for your response. Business logic in the sense after creating the model we will generate source code. For that it was giving the skeleton code. If we want to develop some logic, we have write to the logic or by using some business process we can generate it?
Thanking You,
Kalyani
