Author Topic: Creating shortcut to a model on a server  (Read 3915 times)
mhdhallak
« on: July 15, 2006, 11:08:07 pm »
How can you create a shortcut to directly launch a model stored on an SQL Server database?
AL
Re: Creating shortcut to a model on a server
« Reply #1 on: July 16, 2006, 07:40:09 am »
You can do this. The problem is that I cannot remember exactly how, nor have I been able to find the reply post I received from Sparx some time ago that explained this.
So, to the best of my failing memory...
You need to create a shortcut in windows and associate it with EA. Then you somehow change the <filename.EAP> information in the shortcut to the EA connection string or the data link name (or something). Once that's done (correctly) EA should open the chosen repository at startup.
You'll have to experiement a bit. If it works please post back and tell us which variation on the theme was correct.
Aaron B
« Reply #2 on: July 16, 2006, 04:47:39 pm »
Open your SQL Repository in EA, then use "File -> Save Project As...".  This will prompt to save an EAP file which will behave as a shortcut to your SQL repository.  :)
HTH.
mhdhallak
« Reply #3 on: July 16, 2006, 10:29:34 pm »
HTH.
That worked. Thanks!
AL
