Author Topic: Trouble importing xml files with devices  (Read 2724 times)
mmkja
« on: July 24, 2006, 01:57:05 pm »
     I'm using EA 6.1 build 688 and I'm having problems importing files that came from packages containing "devices' from the deployment tool box.  At first I had a rather large large package but narrowed it down to one node and one device with one association.  Exports ok, but upon importing I get an error pop up with a decription=element content is invalid according tothe dtd/schema. Expecting {UML} modelelement, ....etc.
    I can replace the device with a node and it import ok.  Any ideas how to import a device?  (I don't really want to rework the original package)
Thanks in advance ???
Re: Trouble importing xml files with devices
« Reply #1 on: July 24, 2006, 03:26:57 pm »
You won't get any problems importing (into EA) if you turn off the 'Use DTD' option when exporting.  EA 6.5 should also generate valid elements.
« Last Edit: July 24, 2006, 03:27:12 pm by simonm »
mmkja
« Reply #2 on: July 24, 2006, 03:58:40 pm »
Ah yes, that does work.  thanks much.   when you write "EA 6.5 should also generate valid elements" are  you able to say when 6.5 will be released?
« Reply #3 on: July 24, 2006, 06:26:48 pm »
No. I can't say when it will be released.
