Author Topic: reverse engineering difficulties  (Read 11333 times)
Davedub
« on: July 25, 2006, 07:47:36 am »
I'm currently trying to reverse engineer our existing code using EA. After setting lots of preprocessor macros, EA cannot parse the following lines:
CUnknown * WINAPI AVMonFilter::CreateInstance(LPUNKNOWN pUnk, HRESULT *phr)
I have tried replacing WINAPI with __stdcall to no avail (LPUNKNOWN and HRESULT are already set as preprocessor macros).
Another un-parsable line is:
HRESULT CAVMonFile::LoadCustomProfile( LPCTSTR ptszProfileFileName, IWMProfile ** ppIWMProfile, BOOL& bEmptyVidRect )
Is this a COM issue? (LPCTSTR, BOOL and HRESULT are set as preprocessor macros)
The final problem is the use of the __int64 type being passed as an argument to a macro in this line:
REGENTRY_CONV_NUMERIC_STORAGETYPE(__int64, 28, %I64d, _ttoi64(lpszStr), (__int64)dwDWORD)
EA reports: Unexpected symbol: __int64
I've tried looking around for some detailed documentation on the reverese engineering process, but the help files seem a little sparse.
Can anyone shed light on what's going on? Does anyone know if there is some more detailed information on reverse engineering?
Thanks in advance,
- Dave
Re:  reverse engineering difficulties
« Reply #1 on: July 25, 2006, 03:13:30 pm »
What's going on is that EA totally ignores anything that is defined as a macro.  In the first two examples, having HRESULT and BOOL defined will cause EA to fail to parse.  The reason for this is that EA sees a pointer or reference without a type.
In contrast to that, you will need to define a macro 'REGENTRY_CONV_NUMERIC_STORAGETYPE()' (everything inside the quotes including the brackets) to get get the last line to parse.
What have you read in the help file?
http://www.sparxsystems.com/EAUserGuide/index.html?languagemacros.htm talks about preprocessor macros.
http://www.sparxsystems.com/EAUserGuide/index.html?reverseengineersourcecode.htm is the general reverse engineering help.
