Author Topic: "Issues" Objects Don't Show Up?  (Read 5442 times)
csousa
« on: July 24, 2006, 02:08:52 pm »
I've been experimenting with EA's "issue" objects as a means of quickly annotating a follow-up item/issue on a diagram (e.g., activity diagram).
I created an issue on the diagram using the drag-connector (under common, issue) which creates the issue object, launches the dialogue where I can type a name, alias, and notes, then connects it to a diagram object via a simple trace.
The "issues" created on the diagrams do not seem to appear anywhere I would expect it to (neither in the model issues dialogue or on the project issues reporting mechanism).
They do show up on the relationship matrix which is not necessarily ideal for working through and managing issues across the model.
Any suggestions or am I misunderstanding the purpose of the "issue" object?
« Last Edit: July 24, 2006, 02:10:37 pm by csousa »
Re: "Issues" Objects Don't Show Up?
« Reply #1 on: July 26, 2006, 11:43:08 pm »
Depends where you are currently in the project view. Select the issue object in the diagram, then press Alt+G. You should have the issue in the Project View focus now.
gloubi
« Reply #2 on: August 02, 2006, 06:25:00 am »
Model Issues are not the same as "Issues" objects you take from the toolbox on the left side.
Since you talk of drag & drop, I think you speak of the Issues object of the toolbox, which doesn't appear in the model issues.
Clear?
R -
