Author Topic: Merge / replace actors  (Read 3194 times)
Ronald
« on: August 04, 2006, 01:01:42 am »
Hi All,
Is there some way to merge/ replace double actors?
F.i. I've created actor X and Y, draw up some sequence diagrams and later on I discover that X and Y are actually the same actor, so now I want replace all Y's by X.
Greetings,
Ronald
Re: Merge / replace actors
« Reply #1 on: August 04, 2006, 04:05:03 am »
Not directly. Try the following:
- place both actors in a scratch diagram
- use "Insert related objects" from the context menu
- shift click a relation near X, then click on Y
- new the relation has been moved from X to Y
- repeat for all relations
- ctrl-delete X
Ronald
« Reply #2 on: August 04, 2006, 04:25:55 am »
Thanks for your quick response.
It seems that this applies for a new feature request
« Last Edit: August 04, 2006, 04:53:22 am by Ronald »
