Author Topic: Link filtering possible?  (Read 2994 times)
agent_333
« on: August 03, 2006, 01:07:36 pm »
I'm a new EA user and started a project at work to reverse-engineer some legacy code.  Is it possible to filter the links at the diagram level with a class model?  For instance, I would like only generalization links to be visible and filter out the association links (which cause a lot of clutter) to form a basic class inheritance diagram, but I don't want to manually hide the association links for each individual element.  Any suggestions/comments are greatly appreciated,
Jon
Re: Link filtering possible?
« Reply #1 on: August 04, 2006, 03:53:15 am »
This is not possible directly. You will have to create different diagrams (I do this e.g. for generalization). To populate a diagram you can place a central class on it and from the context menu "Insert Related Objects". You might need to turn of visibility for single relations from the context menu.
agent_333
« Reply #2 on: August 04, 2006, 05:15:22 am »
Understood.  Will give that suggestion a try  :).
Jon
