Author Topic: [Code Template] Changing case of Linked Attribute  (Read 5583 times)
bclark
« on: August 04, 2006, 03:54:12 pm »
I'd like to change the capitalization of my linked attribute when generating source.
Class AbcClass   ---> Association --> Class XyzClass
Source generated for PHP
class AbcClass
   var m_XyzClass;
I'd like it to read
class Abc
   var xyzClass;  <== notice initial lower case
In the "Generate Code" dialog, click advanced.
In the Object Options, select Attribute/Operations
Under the "Attribute Specifications" section I tried changing the "Default name for associated attrib:" to $linkClass but the source generated is:
Class AbcClass
   var XyzClass;
How can I get this to change?  Better yet, how can I get it to use the Association Link NAME -- not class.
Both answers would be great.  If there's any documentation on EA code template syntax, I'd be interested in that as well.
Thanks.
