Author Topic: [PHP Type Hinting] Sync With Source  (Read 6976 times)
bclark
« on: August 04, 2006, 04:22:33 pm »
Creating an operation with type hinted parameters generates code correctly, but when synch'ing with source operation is removed.
Operation foo
Parameters:
[inout] files: array, private: var
Generates Code as:
public function foo(array &$files, $private = false)
Now add a parameter:
public function foo(array &$files, $private = false, array &$extras = null)
And Sync with code.
Result:  Operation disapears from model.
« Last Edit: August 04, 2006, 04:32:28 pm by bclark »
Re: [PHP Type Hinting] Sync With Source
« Reply #1 on: August 06, 2006, 05:22:52 pm »
It looks like any by reference parameter with a type hint is causing a parser to fail to parse that method.  As a result EA is removing the method from the model when reverse engineering (and would cause a duplicate method when forward engineering)
We'll fix this up in a future build.
