Author Topic: Code generation configuration  (Read 2216 times)
colin
« on: August 08, 2006, 12:01:09 pm »
Hi all,
We recenly purchased a number of licenties and are discovering the many benefits of this great tool. I'm new to EA so please bear with me.
I modelled a number of domain classes and subsequently generated the Java code which came out as expected. However I noticed that you can set a prefix on Linked classes m_$LinkedClass which goes against our coding conventions. I removed the prefix but now have the name of the linked class starting with a capital instead of lower case, I guess that's why the prefix was being used ;-).
Is there any way to adjust the names of the attributes so that they are conform our conventions?
examples
private ChildClass m_ChildClass = null;  X
private ChildClass ChildClass = null; X
private ChildClass childClass = null;  yeah :-)
Is this possible?
Colin
Re: Code generation configuration
« Reply #1 on: August 08, 2006, 01:49:33 pm »
colin, EA makes use of a code generation framework which is built-in. You can modify these quite easily and probably manage to produce code in the way you expect it. Go to Setting/Code Gen Templates and read the help related to "code generation". If you're lucky, one of the Sparxians can give you a quick answer.
