Author Topic: Association class, generate code  (Read 3271 times)
jercoli
« on: May 02, 2006, 11:43:06 am »
I make a simple association class (source code:java), and the generate code not include attributes of both classes associated.
Ex:
Person associate with Company
Job (associate class)
In Job must have : Person m_Person and Company m_Company, but the code not include this.
Solution??, Thanks in advance.
Re: Association class, generate code
« Reply #1 on: May 03, 2006, 03:22:30 pm »
Sorry, but EA currently doesn't generate code from association classes.
If you generate all three classes you will see attributes generated as if the Job class was completely unconnected.
« Reply #2 on: May 03, 2006, 03:37:57 pm »
Simon,
Can we get at the association classes from custom scripts somehow? Or perhaps via automation. I know they can be identified via automation but keep thinking (it was a while back that I did this) that I need to read the back end database records directly.
Surely there is a more elegant way.
TIA,
« Reply #3 on: May 03, 2006, 03:55:10 pm »
It is possible to get it from the automation interface, although I don't deal with that often.
From the class side you can look for Type=="Class" and Subtype==17.  If that is true then MiscData[3] (PDATA4)
corresponds to the Connector ID of the association.
From the association side look for Type=="Association" and Subtype=="Class".  If that is true then PDATA1 corresponds to the Object ID of the class, although I can't find this in the automation interface documentation.
« Reply #4 on: May 03, 2006, 04:25:10 pm »
Thanks Simon,
That sounds like how I managed from the Class side. I was unaware of the approach from the association side. This will allow me to avoid some strange roundabout queries on the background data channel.
cgaviao
« Reply #5 on: August 12, 2006, 05:39:29 am »
Hi, I would like to know if on ea v6.5 this will be provided.
thanks
Cristiano
