Author Topic: Creating customized RTF template  (Read 4885 times)
Ashish_Mehta
« on: January 07, 2008, 05:22:54 am »
Hi frenz,
I want to create a RTF template that could pick elements from a package according to there type and display them.
Please reply if it is possible.
TIA
Ashish_Mehta
Re: Creating customized RTF template
« Reply #1 on: January 07, 2008, 06:25:17 am »
Also, If someone could provide some references about using bookmarks to pick elements from model into RTF reports then it'll be great
Oliver F.
    • Karl Storz homepage
« Reply #2 on: January 09, 2008, 07:58:36 am »
Hi frenz,
If you would like to include only certain types in the RTF (actions, components, classes, etc.) you could use the "Generate options" dialog from documentation panel and exclude the details for all types you would not like to see.
Unfortunately EA does not save those settings so you will have to repeat that step any time you are generating the doc.
Other alternative: Put all unwanted types in a package, then go to its context menu and choose Documentation ->Ret Report options and mark it as excluded for RTF documentation.
If none of this is sufficient you will have to write your own export addin.
Oliver
Ashish_Mehta
« Reply #3 on: January 09, 2008, 08:27:16 pm »
Thanks Oliver!!
Actually i want the template to check the type & name of the element before including in the RTF report.
Could you tell me more about writing my own export addin.
Where do i get reference material for it.
TIA
Oliver F.
« Reply #4 on: January 10, 2008, 12:04:11 am »
Unfortunately I have not played around with writing addins yet.
There is some information in the help files and I believe there is a document in the SparxSystems support area.
Good luck.
Oliver
