Author Topic: Documentation of an Access DB  (Read 5307 times)
Felix23
« on: August 21, 2006, 06:27:21 am »
Hi@all,
is it possible to document an MS Access Database?
« Last Edit: August 21, 2006, 06:27:55 am by Felix23 »
sargasso
Re: Documentation of an Access DB
« Reply #1 on: August 21, 2006, 06:31:14 am »
Yes ..... and no.  Try to be a touch more specific.
bruce
Felix23
« Reply #2 on: August 21, 2006, 06:46:44 am »
Ok. I'v got a MS Access Database and I'm looking for a way to export it to Enterprise Architect to documant this Database.
Is it possible?
sargasso
« Reply #3 on: August 21, 2006, 06:53:37 am »
Refer to help contents "Data Modelling" and specifically, "Import Database Schema from ODBC"
hth
bruce
« Reply #4 on: August 21, 2006, 02:58:29 pm »
Felix,
Please note that EA fails to properly handle Access GUID (Replication_ID) data type. I've mentioned this to Sparx on two occasions, with an explanation of how to distinguish this type from un unsized text field via DAO, ODBC and ADO but have not managed to get any traction.
Other than this flaw EA seems to do a good job with Access databases.
Remember that you will have to connect to the database as a Windows data source when you do the reverse engineering. Just follow the dialogs and you should be fine. The EA help has little on this, but that's because the dialogs and functionality is provided directly by Windows.
sargasso
« Reply #5 on: August 21, 2006, 04:14:54 pm »
Midnight,
Could you provide details of that here. AFAIK all these i/fs return the string rep rather than the actual binary.
bruce
« Reply #6 on: August 21, 2006, 04:18:50 pm »
Bruce,
It's been a while, but I think I posted the whole thing in the forum here. Try searching - I'm the author.
sargasso
« Reply #7 on: August 21, 2006, 05:19:12 pm »
Hmmm,
The only one I found was http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1138557908;start=2#2
which was exactly the same discussion.  :(
bruce
« Reply #8 on: August 22, 2006, 04:22:35 am »
I checked my email logs but found nothing on this. I'll see if I can find it anywhere else.
Otherwise I'll have to find the source material again, which shouldn't be too difficult. It's just a matter of time.
