Author Topic: How can I use Enterprise Architect for Team work?  (Read 4143 times)
kt1
« on: August 23, 2006, 07:07:30 pm »
Can you help me the way that my team can work with Enterprise Architect? I want to share data as team work server with features: user's permission, check-in, check-out, version control, ... At now, I use Enterprise Architect Corporate Edition for my work.
Jan ´Bary´ Glas
  • Bary
Re: How can I use Enterprise Architect for Team wo
« Reply #1 on: August 23, 2006, 11:25:05 pm »
For your team work seems suitable setting up a database repository on your team work server:
First you have to prepare the database with script provided by Sparx and than just start a new repository project, enable security and set need of user locks to change elements. As an administrator of that repository you can allow different users access different elements/packages/views.
I am not sure what you mean by check-in/out, but logging of user activity is (as far as I know) not provided within EA. You can see (and report) who creted which element.
The versioning is possible in EA via CVS and others. Investigate in help and this forum, I do not use it myself and do not want to confuse you.
Jan 'Bary' Glas
Jan Pacovsky
  • I just love EA... ;-)
« Reply #2 on: August 24, 2006, 12:31:19 am »
Using version control in EA is quite simple. See this Sparx manual about version control: http://www.sparxsystems.com/WhitePapers/Version_Control.pdf.
More difficult is to decide wich way to deploy EA in order it can support your needs. See different deployment schemas in above-mentioned tutorial. Each deployment model has it's cons and pros. (see also my topic http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=general;action=display;num=1156336926)
Hugo
  • Where there's a will there's a way.
« Reply #3 on: August 24, 2006, 12:52:39 pm »
Has anyone had success integrating EA with Vault, the SQL based SCC that competes strongly with Microsoft's Source Safe?
Thx
Hugh
« Reply #4 on: August 24, 2006, 01:44:24 pm »
Hugh, maybe you should try the search function. It revealed an answer at once.
