Author Topic: Phantom Foreign Keys (Cannot Delete)  (Read 3030 times)
lipmanc
« on: August 27, 2006, 05:38:53 pm »
I have a couple of data model tables and created an association between, which generated a foreign key in the format FK_SourceTableName_TargetTableName.  Usually, if I delete the association, the foreign key is dropped as well; however, every once in a while it does not drop and if I try to  recreate the association, it says a FK with this name already exists.  (I could just give it another name, but I don't know why the original FK remains.)
I know I can delete the FK from the Operations dialog but it warns me that continueing could cause inconsistencies (and recommends that I use the FK dialog).
Why does the phantom FK remain and how do I determine whether there will be any issues if I forcably delete it from the Operations dialog?
Re: Phantom Foreign Keys (Cannot Delete)
« Reply #1 on: August 28, 2006, 03:33:21 am »
I eventually had the same problem with code transformation. I just remember that I started clicking/deleting around until it was okay again. It did not happen very often and I claimed it to me making wrong transformation code.
lipmanc
« Reply #2 on: August 28, 2006, 05:49:27 am »
Thanks, but I'm not doing anything with transform code (to my knowledge).
My DLL ported out to SQL Server okay.  I just hope that I don't have a referential integrity issue that's going to haunt me in the future (either in the implementation or even while modeling within EA).
« Reply #3 on: August 28, 2006, 10:10:51 am »
Sometimes it helps to run the integrity check (Tools/Data Management). I have no better advice :-/
