Author Topic: UML profiles - where stored?  (Read 2326 times)
Dave_Bullet
« on: August 30, 2006, 06:21:34 pm »
Does anyone know where UML profiles are stored?
If in the database - which tables?
Reason being - I want to write some scripts to workaround a couple of bugs with "sync tagged values"
1. Inherited stereotype attributes work for new elements added to the model, but only the leaf most stereotype attributes are added on a sync tagged values (not inherited attrbutes)
2. If a tagged value is removed from the profile - it remains in the elements that used it (I want to delete it)
Cheers,
David.
Dave_Bullet
Re: UML profiles - where stored?
« Reply #1 on: August 30, 2006, 06:32:52 pm »
Found the answer - t_trxtypes - in the notes field (thanks to SQL profiler)
David.
